04 Koni's on an 03
Discussion in 'Modifications & DIY how-to' started by Sparta, Jun 1, 2007.
  1. Sparta
    What exactly would I need to put Koni shocks with STI springs off of an 04 WRX onto my 03 Wagon? And vice versa if I traded mine, what would he need to put my 03 shocks on his 04?
  2. yerrow
    yerrow Active Member
    iirc i think just tophats
  3. gotsol
    gotsol Active Member
    do you have 02-03 Koni's? I have 02-03 koni's with 04 springs and tophats. I just stacked washers in the tophat below the nut so it would tighten. I've had it like that for years.
    However, It sounds like the setup you're looking at is already assembled. It will bolt right up, no problem. But I don't know if the wagon would need anything different
  4. GTscoob
    Sedan struts on a wagon makes negative camber very hard to come by. Vice versa, wagon struts on a sedan will result in lots of static negative camber without any adjustments.
  5. mmtasty
    mmtasty Active Member
    but if they're Koni inserts, then he'd be using his lowers, right??? and it wouldn't matter.
  6. Sparta
    Thanks. So it wouldn't be good for me to get the Koni's off of the 04 sedan?
  7. GTscoob
    I'm assuming he's talking about BelvnAWDs Konis for sale. You hack up your stock struts with konis and use lower section but Scott needs a set of struts to trade his car in with.
  8. mmtasty
    oooh... way to go Matlock.
  9. gotsol
    so if you wanted to use them you could just get a set of ingals camber bolts for $20 from summit racing and call it done
  10. BelvnAWD
    But I am trying to return my car to stock and sell it, lots of negative camber = bad resale value for me...:hsugh:
  11. socrates42
    socrates42 Member
    love the sig belvin....
