04 sti CDV = clutch slip?
Discussion in 'Modifications & DIY how-to' started by STillGruven, Jan 24, 2011.
  1. STillGruven
    STillGruven Member
    Nov 30, 2009
    83
    0
    I have recently had an event that has me concerned.
    I was on a slight hill at speed and wanted to demonstrate the rapid acceleration of the STi.
    I downshifted from 5th to 4th and let out the clutch and hit the gas.
    The revs climbed rapidly out of proportion to the vehicle speed. I let off the gas and up shifted to 5th and again the revs climbed quicker than the speed of the car. In a few seconds the car was filled with the smell of cooked clutch.
    I have 43K on the car and no serious mods. I took it in to the dealer and they test drove it and said everything seemed fine. There was the slight smell of cooked clutch after their test drive. They said I may have cleaned off some glazing off of the disk and flywheel and that I shouldn't worry about it.
    The clutch pedal feels differently to me now and the clutch seems to disengage with very little pedal travel.
    I also noticed that my cruise control would not stay "SET" the other morning. It was acting as if the clutch pedal was being pushed in.
    Does the 04 STi have a CDV to prevent harsh clutch dumps? Would this cause the slippage in higher gears with high revs?
    Any input is appreciated.
    Thanks
    Michael
  2. Alex
    Alex Community Founder
    Staff Member
    Oct 7, 2003
    15,892
    20
    No, not that I'm aware of. You can break your rear axles if you're so inclined on a hard dump. The cruise control thing seems to be a bit of a common problem with the 2004 STis. There's a neutral position sensor, mounted above the transmission that requires removal of transmission to access, that apparently dies quickly. Mine's been on the fritz for some time now. I rarely used cruise control to begin with and I'm certainly not going to drop the transmission to replace a tiny sensor.
  3. b reel
    Oct 27, 2008
    3,285
    15
    there's a mod for that and who's to say the man didn't do some clutch dumps in his day?
    I think it's a couple of copper washers and a oil fill plug on that mod to the slave cylinder.
  4. Alex
    Staff Member
    Oct 7, 2003
    15,892
    20
    A good clutch dump is healthy now and then ;)
  5. superdoughboy4
    Nov 19, 2009
    1,140
    0
    Did you happen to say, "Watch THIS!", in a rather enthusiastic way while trying to accelerate up the hill quickly?
    If so, you probably jinxed it.
    #5 superdoughboy4, Jan 24, 2011
  6. SubieEngineer
    SubieEngineer Member
    Jan 6, 2010
    226
    10
    :rofl: Famous last words!
    Sort of sounds like the clutch slipping...
  7. WJM
    Dec 12, 2004
    5,401
    0
    The CDV is not a significant piece of hardware and does NOT prevent sidesteps/dumps at all.
    But, saying "watch this" or "whats the worst that can happen" or any version of those will result in failure of said event.
    *COUGH* gotsol *COUGH*
  8. wrxin8or
    wrxin8or Mullitt
    Staff Member
    Feb 7, 2005
    4,190
    1
    wait....weren't you the one who destroyed his axle?
  9. Cool_____
    Sep 5, 2005
    7,338
    0
    I was able to change mine without removal of anything but the switch. What a PITA but was doable.
  10. WJM
    Dec 12, 2004
    5,401
    0
    After he said the magic automatic failure phrase. :rofl:
    But I promptly replaced his broke ass axle with a BRAND NEW one minutes later.
  11. Mike@TTR
    Mike@TTR Active Member
    Jan 12, 2009
    1,329
    0
    Many times a clutch will begin slipping in higher gears with heavy load first. It generally goes down hill from there.
  12. STillGruven
    STillGruven Member
    Nov 30, 2009
    83
    0
    Yeah, I did.
    You know I did.
    It still was faster than anything they had been in before!
  13. STillGruven
    STillGruven Member
    Nov 30, 2009
    83
    0
    I'll start saving
    Ok - now I am off to the clutch thread to read what wisdom there is regarding clutch choices.
    I about fell over when I found out how much the upgraded STi parts are.
    Thanks for all of the replies. Got me laughing!
  14. WJM
    Dec 12, 2004
    5,401
    0
    Those STi/SPT clutch parts are JUNK and about 1,000,000% overpriced.
    The ACT HDSS kit is the only way to go. The pedal is stiffer but its the best streetable clutch money can buy.
    Otherwise, put a stock kit back in it.
