04 STI Engine knock (video)
Discussion in 'Modifications & DIY how-to' started by Timberwolf0924, Jul 29, 2010.
  1. I'm looking to find out whats up with my subaru. It just recently started knocking, like 2 days ago. You can hear the knock at 21s and 29s-31s. It sounds like a piston or lifter. Any ideas? Over a year ago my timing threw, and I had it repaired, DIY job, but it worked fine.
    Please Help!!
    http://www.youtube.com/watch?v=-KYef-67bPk
  2. Mike@TTR
    Mike@TTR Active Member
    Well....you don't have lifters. The rockers ride directly on the cams and the valves are on the other side. Hard to tell from the video, but kind of sounds like rod bearing. I guess you checked for anything hitting?
  3. Mike@TTR
    One thing you can do is drain the oil and look for metallic flakes in the oil. If it is a bearing you should be able to see something.
  4. integroid
    that doesnt sound good. I think a new shortblock is in your near future,
  5. That my friend is a rod!
  6. Bug-Rex
    Bug-Rex Active Member
    That sounds to me like its time to take it to Killshot Performance!
  7. Mike@TTR
    We will be happy to help out in any way we can. But I will say, once mine started doing that, it only made it about 1/4 of a mile before it bit the dust :( The good part was I was waiting for the day so that I could start on a EJ257 build that could take some serious punishment :)
  8. Alex
    Wirelessly posted
    I'm sure any of our sponsors would be happy to take a look at your motor.
  9. STillGruven
    STillGruven Member
  10. Kokopelli
    Check the oil for metal. You will know right away if the bearing are the problem.
  11. Cool_____
    Time for a Topspeed SS1 block!
  12. Mike@TTR
    We are checking it out for him here soon.
  13. Matt@Topspeed
    Matt@Topspeed Member
    All the cool kids are doing it.
  14. Mike@TTR
    Lmao. Thankfully I was not drinking anything at the time. Have not heard that one in a while :)
