05 Rear Diff Clunk w/ Agressive Clutch
Discussion in 'Modifications & DIY how-to' started by flip, Mar 28, 2007.
  1. flip
    flip Member
    Ever since I've had my new 3 puck stage 2 clutch in I'm hearing a slight clunk in between shifts from the rear. Its not to concerning since it's nothing crazy but I'm just wondering whats causing it. My guess is that it's a soft bushing thats not meant to handle a more agressive clutch and more than stock power... My clutch grabs REALLY hard so...
    I searched around and found a few people experiencing similar problems but didn't feel like any of them were the exact same...
    Anyone have any experience with this problem?
  2. jonnyboy0150
    jonnyboy0150 Member
    Super common problem. Whiteline and Kartboy make a rear diff bushing set that fixes the problem.
  3. pEd
    ^^ sounds about right to me.
    If you've got too agressive of a clutch, you may want to start saving up for axles, though
    I'm not sure how much power you're putting down. Those are the next thing in line to break.
  4. kingwrex
    kingwrex Supporting Member
    i have stage 3 six puck clutch and it grabbs really hard, ans would judder the whole car at times when i was getting used to it. i installed a sti solid transmission mount and it helped a ton.
  5. AXLEJOHNSON
    AXLEJOHNSON Member
    I have had the same sound from my trunk, it used to bother me a lot, but now I am used to it, but eventually I am going to replace those bushings and see how that takes care of it.
  6. Greg
    Greg Active Member
    Axles... :squint:
  7. monk
    do they make diff lock-down bolts for the sti? i had them on my 04 wrx. they were nice.
  8. pEd
    ^^ yes, they do
  9. flip
    flip Member
    Ok, good thats what I thought. The noise doesn't REALLY bother me but you know...
    Lock down bolts? I'm assuming they just act like a solid bushing? I'd probly go with the whiteline bushings or something. That sounds a tad easier on stuff :).
    I'm only putting down around 320 and 360 to the wheels right now so it's nothing too crazy.
  10. Alex
    You need to buy unabomber's sexy rear end from TIC.
  11. GTscoob
    Turn In Concepts Clunk Killer should do you right. I plan on picking one up by the summer.
    You can slip the clutch more and not get the clunk but then you're just burning out your clutch.
