06 STI stripped bolt on rotor
Discussion in 'Modifications & DIY how-to' started by nicali, Mar 12, 2008.
  1. nicali
    nicali Member
    Sep 14, 2006
    37
    0
    I have 1 stripped bolt on the driver side rear rotor and wondered if that is an easy fix or not? I can get 4 of the 5 nuts on the wheel, but the last one just refuses to go on. I checked the bolt carefully and the intial 2 threads on the bolt are stripped.
  2. Trey
    Trey Active Member
    Mar 20, 2005
    1,322
    0
    Usually you can get a die and clean up the threads. I forget what the thread pitch is though.
    You could take a lug nut to ACE and find a bolt that threads into the lug nut. Then you'll know what the thread pitch so you can buy your die.
  3. Matt
    Matt Think before you post
    Staff Member Supporting Member
    Oct 8, 2003
    8,409
    23
    I'm not sure, but I THINK the pitch is 12x1.25....same as the gear shifter....BUT, I may be wrong
  4. Alex
    Alex Community Founder
    Staff Member
    Oct 7, 2003
    15,892
    20
    It is 12 x 1.25
    #4 Alex, Mar 12, 2008
  5. importracer689
    Sep 6, 2007
    100
    0
    hey,
    i concur the thread pitch is indeed m12x1.25
    if it is a lug nut that is stripped, you can replace the nut, but if the stud is stripped you will have to do that as well, but its not a really big deal. you can pick one up anywhere and they usually just knock/pull in with the nut tension.
    mark
  6. goixiz
    goixiz Active Member
    Oct 23, 2005
    1,482
    0
    I have both tap and die for M12x1.25 for my short shifters so if you let me know when you are in Gwinnett ill have it in my car and i can chase the thread for you. If you send me the part i can do that as well - you pay shipping both ways, my few minutes to do that is free
