11mm Oil Pump Question
Discussion in 'Modifications & DIY how-to' started by Ken, Mar 21, 2011.
  1. Ken
    Ken New Member
    Quick question guys, i'm gathering the final pieces to do a 2.5/2.0 hybrid and i am going with a 11mm oil pump. I was just wondering if i need to replace my factory oil pick up tube with a one out of a 2.5 or are they the same?
  2. Kokopelli
    Depends on what oil pan you are using.
  3. slowwrx
    You should replace it with an aftermarket pickup
  4. Alex
    It may be in your best interest to go ahead and pickup a reinforced one -- Moroso, Killer B, etc.
  5. slowwrx
    thats so weird I had a detailed post about why typed out and its just gone.
    Long story short the factory pickups break, you should buy a aftermarket one.
    We usually keep them in stock at TopSpeed.
    Matt
  6. b reel
    you could do a KillerB pickup with a 2.5L pan.
  7. Ken
    Ken New Member
    Ok cool thanks guys, I'll probably go ahead and order one from topspeed tonight.
  8. Alex
    Probably a good idea :)
  9. Cool_____
    why you doing 11mm pump? Stock Sti pump is plenty.
  10. slowwrx
    11mm is the new stock sti pump
  11. Cool_____
    I know that but the older ones are just fine too.
