Inspect Clutch operation Replace Engine oil Replace Engine oil filter Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions Inspect Steering and suspension Perform Inspect brake lines and check operation of parking and service brake system Perform Rotate and Inspect Tires If you're not on my.subaru.com, check it out...it details all of the services, as well as any warranty info, recalls, etc.
