Hey i live in Midtown. I wante to know if anyone is running any of the mitsubishi turbos and/or a Cobb Exhaust? I have a 06 WRX and I'm looking to do a TBE this summer and possibly a turbo. I'm stuck between the BIG 16G or a TD05 8cm^2 18G. Then again i can be persuaded to get a 20g if i can experience it. SO IM ASKING: If someone does have a setup like this can I get a ride-along so i can judge for myself what to do?
That is a good thought. I think that I am set on a EVO III 16g, but would like a ride in a current setup.
i'd recommend a 20g... from what i hear, with a full exhaust, it will outspool a stock setup and make a good amount of power... in my opinion, the 20g is probably the best sized turbo for the EJ25 is you plan to stick with 93 octane
Turboback>Cobb AP>Cobb Stage2>Larger Intercooler>Walhboro + Injectors>... then 20g. Your 06 WRX could be faster than a stock STi without spending odles of money on a 20g. You can push the stock turbo close to 300hp at the crank. Get the supporting mods then worry about the turbo, because I am sure by that time there will be new and better models of turbos.
yea im trying to get around buying new injectors and im not shooting for 350+ at the wheel. Im trying to get around 300-320 at the wheels in the long run. Plus i mean if all else fails i can just sell the turbo and pick up a 20g when im ready. thanks for the help so far tho
16g and 18g are only for the 2.0L. Trust me you will creep like a madman on the 2.5L with the 18g or the s16g. For the 2.5L the smallest I would go is the 20g. If you get the 20g get the td06h with the 8cm housing. But first you need to support everything else.....don't just dive into a big turbo. Do just like Clemsonscooby above said.
my STi made 318 whp and 366 lb-ft with a TBE, TMIC and tuning on the stock vf39... if thats ur long term goal, u dont need to go with the 20g... and ur current injectors should be able to suffice too i'd expect you to be in a similar ball park with a VF39 and big TMIC
exactly... but the response is amazing and if thats all the top end power he wants, then that setup should suit him fine
if you really want to upgrade your turbo... go with the 20g(td06) and spice it up with some meth + tune great combo..... thats what im shoting for.... later though
Wouldn't you want to run at least 800 injectors with that 20G, that's what I run on 20GTD05 04 wrx setup, I know 06 is a little different.
