2.0 to 2.5 swap INFO + Installation
Discussion in 'Modifications & DIY how-to' started by subarusti4life, Aug 14, 2010.
  1. hey all, I know this probably has been asked before, but I need to make sure about this before proceeding, also if you know anyone who can do this swap, contact me-- I want to get this done by or before the 2nd week of Sept
    my questions are this-- I can go get a new 2.5 SB from SOK and use the list below for the rest of the parts-- but it seems to be missing the idler pulleys and such for timing-- I know I can get a whole gates kit offline but does anyone know that i need the idlers or can i reuse my old ones? I dont feel safe using old stuff--not trying to be dumb on this one :)
    question is , can anyone help me track down ALL the parts? or is the list perfect w/o idlers?
    other questions are
    does anyone know if EJ20R heads will swap on?
    is the stock block capable of getting me 350-375 whp without frying the engine
    I have 700CC inje, FMIC, turbo back full 3" exhaust, catless uppipe, JVTR racing manifold, standalone megasquirt.? on gas
    rotated kit vs stock location? why do rotated over a GT30R or something?
    thanks for this swap list
    Part Part # Qty Unit Price Total
    Timing Belt 13028AA240 1 112.46 112.46
    Tensioner 13033AA042 1 107.74 107.74
    Oil Pump (10mm) 15010AA300 1 104.96 104.96
    Oil Pump (11MM 08+) 15010AA360 1 Te a price
    Oil Pump o-ring 10991AA001 1 1.46 1.46
    Oil pan return o-ring 11122AA340 1 10.96 10.96
    Oil Pickup tube o-ring 806917080 1 0.9 0.9
    Coolant crosspipe o-rings 806933010 2 2.85 5.7
    Oil cooler o-ring 21370KA001 1 4.36 4.36
    Water Pump 21111AA240 1 89.96 89.96
    Water Pump Gasket 21114AA051 1 2.3 2.3
    Crankshaft Seal 806733030 1 6.01 6.01
    Intake Cam Seals 806732160 2 4.46 8.92 -- 806742160 for STi AVCS heads
    Exhaust Cam Seals 806732160 2 4.46 8.92
    STi Head Gaskets 11044AA642 2 29.96 59.92
    Valve Cover Gaskets (L) 13272AA094 1 7.46 7.46 -- 13272AA140 for STi AVCS heads
    Valve Cover Gaskets (R) 13270AA162 1 7.46 7.46 -- 13270AA190 for STi AVCS heads
    Spark plug valve cover gaskets 13293AA051 4 5.96 23.84 -- same part for STi AVCS heads
    Oil Filter 15208AA100 1 5.89 5.89
    Oil Filter Washer 11126AA000 1 0.87 0.87
    Intake manifold gaskets 14035AA421 2 4.05 8.1
    Ext Manifold gaskets 14038AA000 2 11.64 23.28
    Turbo Gasket to DP 44022AA180 1 16.46 16.46
    UP gasket Lower 44022AA150 1 10.41 10.41
    UP gasket upper 44022AA170 1 10.41 10.41
    Headbolts 11095AA042 12 7.44 89.28
    Valve cover bolt grommets 13271AA071 16 2.57 41.12
    Fujibond 004403007
    Total Price 769.15
  2. Mike@TTR
    Mike@TTR Active Member
    Sent ya a pm about the block. We have a hook up on that one right now. Built block for cheaper than a stock short block. We also have a set of heads available. As for the turbo. A GT30R is a rotated turbo unless you are talking about one of the stock location set ups. Those will generally end up costing almost as much as a rotated set up by the time you get an external gate, up pipe, down pipe, turbo, etc. Give me a call if you have any questions.
  3. I did that migration as well. Except instead of 2.0 heads I got a Sti long block and wrx intake manifold. Heads were built. 20g turbo with the neccessary goodies execpt avcs and better than stock intercooler (have to save up again for the intercooler lol). but turned out really well. 344hp on my setup.
  4. Mike@TTR
    Get the SSAC/XS power front mount intercooler. Pretty cheap and has been proven to work well.
  5. Tray@Forged
    Tray@Forged Member
    If you would like some assistance with your project please let me know. I would be happy to help you. We have fast turn around time for hybrid swaps and we can get the car completed before your September deadline.
    Best regards,
    Tray
