here's my 1st run at 206 something http://videos.streetfire.net/player.aspx?fileid=54A5C240-11FA-4C29-BEFF-C072FA35C3AB here's 219/220 Cobb stage 2, i don't think TS's dyno likes me all that much http://videos.streetfire.net/player.aspx?fileid=55F45474-DD64-40FA-9EEB-4B8E59F1069E here's Genya's 462+ish with a leaking meth pump http://videos.streetfire.net/player.aspx?fileid=CDDD8217-3AEC-486A-8906-6286EAD9B78C not TOO big of a difference between mine and genya's
323/308... there are 2 differences however: 1) roller vs. chassis: doubt that makes much of a difference 2) cooling the TMIC: at SOG theres a fan blowing air straight through the TMIC vs at TS, my IC was hosed down a little between the runs also the difference between my 1st run and second run was over 15lb-ft i believe... i wish they did more runs until the readings stabilized scott did play with the tune after i dyno'd at SOG... im gonna dyno again at SOG whenever i get the time to go up there so i can get a good comparison
