Has anyone else had a problem fitting the Whiteline 24mm rear sway bar bushings to the Whiteline upgraded mounts? The bushing seems too narrow for the U-bracket.
i had issues installing the bushings with the stock mounts... the bushings were too big in my case.... needed some cutting and longer bolts
I had the same issue as Milo, the bushing was too large for the stock mounts....had to use the stock bushings on the new bar....
Thanks guys. I'll call whiteline and ask them what the problem is. Maybe i'll get some free bushings out of it. Mere, Brian, and I put the stock mounts back on and it works beautifully. I guess I'll just ahve to see what whiteline says. SonicBoom do you still have your old bushings? I wonder if they fit the whiteline mounts....
