http://www.wrxatlanta.com/forums/vbpicgallery.php?do=view&g=182 Those are pix of them installed. The installation of the kit itself was not hard at all. Writeups can be found on Nasioc and IWSTI. Upon installation and alignment of the car, there was a major increase in front grip. This decreased the amount of understeer in the car without making it oversteer. I could go deeper into a turn before experiencing understeer. This did as much for the car as an anti-lift kit or coilovers did. This is an awesome mod. Mod List: OBX Front LSD Megan Racing Coilovers Whiteline 24mm FSB Perrin 26mm RSB Custom Front Tower Bar Whiteline Offset Bushings STI v8 aluminum control arms Various Bushings around the car Misc braces for the GC body Alignment Specs: Front: -2.9 camber Rear -1.5 camber 0 Toe 5.1 degress of caster.
Nice, did you have an opinion as to what advantage this kit has over the Whiteline kit? I know the ball joint and tie rod end is a Whiteline propriety product
Essentially the 6gun kit is a 40mm drop in the control arms and tierods. The Whiteline is only a 10mm. The 6gun kit is going to put you in a better camber no matter your ride height compared to the Whiteline kit. I would suggest the whiteline as a cheaper more daily driving mod, as the 6gun as a more hardcore racing kit. Not to say daily driver's can't use it (mine's a daily), but the whiteline is cheaper. The 6gun is going to be a lot better though. The charts that whiteline and 6gun have posted up suggest the whiteline doesn't do enough for the money. Plus if you think about it, this isn't something you upgrade often. You pay one big price then you're done, so don't skimp.
