a/f gauge install
Discussion in 'Modifications & DIY how-to' started by Hughes8418, Apr 11, 2007.
  1. Hughes8418
    Hughes8418 Member
    What wire do you splice into on the a/f gauge install?
  2. gte123v
    gte123v Member
    Is it a wideband gauge? Otherwise it's just a light show once you get it wired in.
  3. Hughes8418
    Hughes8418 Member
    well i got egt boost oil and water and i had one more hole to fill so i just got the a.f and i am starting to install them i know how to do all but the a/f i dont know what wire to splice into
  4. jonnyboy0150
    jonnyboy0150 Member
    You are going to need a wideband o2 sensor in order for that gauge to work properly. I would NOT recommend splicing that into the factory o2.
  5. moose
    Yeah, I agree that an a/f gauge on a stock o2 sensor is a waste of time... it really doesn't tell you much of anything. If you have oil temp, add pressure or vice versa if you ask me. :)
  6. clemsonscooby
    clemsonscooby Active Member
    You would also probably need a bung welded onto your dp. But I believe its supposed to be done at least 12" away from the turbo. My guess is that if you didn't pay more than $200 for the a/f gauge than its one of the worthless gauges ("light show").
  7. moose
    With something like an LC-1 wideband you can rescale one of the analog outputs to 0-1v range and use a narrowband gauge successfully and usefully. :)
