A New belt noise thread...
Discussion in 'Modifications & DIY how-to' started by Slowsoul, Dec 7, 2008.
  1. Slowsoul
    Slowsoul Member
    My squealing belts are KILLING me...
    I did my timing belt a few weeks ago and ever since my alternator and power steering belts just wont quiet down, they are both just loud as hell until they warm up.
    Does anyone know the proper tension on those belts? I might have them too tight.
  2. nicad
  3. Slowsoul
    Slowsoul Member
    Thank you for that.
    What is weird is that I can't tighten the alternator tensioner anymore than it already is...and there is still a considerable amount of slack in the belt.
    I feel like an idoit...it is just a belt tensioner.
  4. nicad
    did you loosen the locknut?
  5. Slowsoul
    Slowsoul Member
    Yeah...it is like I am out of adjustment...like I have reached the top of the adjustment slot.
  6. crashtke
    These new belts? Also as I have mentioned to others check the AC pulley...it grenaded on my car after only 90k miles!!! Took a chunk out of my timing belt cover too...had it made it through the timing cover, it could have caused a large issue!
  7. Slowsoul
    Slowsoul Member
    Yes, brand new belts. The AC pulley looks okay.
  8. crashtke
    If you want give me a call. I can try to take a look for you. I went through this too.
  9. Slowsoul
    Slowsoul Member
    Okay, thanks...I have your number. If I don't get this figured out in the next couple of days, maybe I will stop by.
