ABS light? Cel codes?
Discussion in 'General Community' started by Deke, Aug 9, 2006.
  1. Deke
    Deke Active Member
    So I was sitting in traffic the other day. The AC was on full blast and I was playing music. All of a sudden the AC cuts back, the music cuts off, and my ABS light comes on. It only happenned for probably a second (the abs light stayed on like 3) and then everything went back to normal. Any clue what this was? It happened twice yesterday, but the first time it was only the abs light that came on.
    On a seemingly unrelated note. If I reflash my ecu does it delete previous cel codes? Or are they still stored?
  2. moose
    Sounds like you had a power hiccup. Might want to check your grounds and other major electrical connections.
  3. nsvwrx
    nsvwrx Active Member
    i had that happen to me once.. al my gauges died too, whiile driving too
    turned out my alternater went bad
