ACPT Driveshaft
Discussion in 'Modifications & DIY how-to' started by blindfold, Nov 8, 2006.
  1. blindfold
    blindfold Active Member
    Anyone local in the Metro Atlanta Area have a ACPT driveshaft in their STi? If you do, please share your experience. Kind of intersted how it really is since I read so much about it on IWSTI.com, thank you.
    sincerely
    Ming
  2. pEd
    +1 on this.....
    There seems to be a lot of hype over there about this thing.
  3. calmnothing
    It should pretty much feel like a lightweight flyweheel and pulleys no?
  4. miloman
    actually no... it should feel more like light wheels
    a lighter driveshaft will not reduce the rotational inertia of the crank (like pulleys and flywheels do)... it will reduce the rotational inertia of the drivetrain
  5. blindfold
    Yup, and I read that higher gear accelerate has been enhanced the most. So overall this would translate to that the rate of putting-power-to-the- ground is increased ? There is a slight increase of area under the curve according to dyno graphs posted on iwsti.com.
    I was being curious and was looking forward to get a ride from someone who has the driveshaft because $1200 is no chump change.
