adjust tien flex coils?
Discussion in 'Modifications & DIY how-to' started by 7wolf, Sep 30, 2005.
  1. 7wolf
    7wolf Member
    i've got some tein flex coils on my 02 wrx and totally forget how adjustable they are. i don't know how far to turn them for a softer or stiffer ride. i don't want to mess things up by turning them too far but i want to mess with the damping a little. please help...
  2. miloman
    they should be 24 point adjustable... clockwise to tighten, counter clockwise to soften... i have upgraded springs on mine... i like setting them to 14 clicks from softest in the rear and 11 clicks from softest in front
    dont worry about playing with them... but ive heard dont go below 8 clicks from softest
  3. 1984
    1984 Member
    Are you sure it's 24? I'm almost positive that it's 16.
  4. miloman
    mine's 24
  5. monk
    milo, can you tell me where your hieght is set to? i should have mine installed by saturday.
  6. miloman
    i have no idea... i haven't tinkered with the height since i had them installed over a year ago
  7. j69raw
    j69raw Member
    I just got my Tein Flex about a month ago and mine are 16 way adj.
    I had Tein Flex on my 2002 WRX and I believe they were 24 way adj.
    Maybe, Tein changed the setup on the Flex line from 24 to 16!
    The new Flex goes past the 16 clicks but, in the manual it says it will damage it, if you do!
  8. 7wolf
    7wolf Member
    thanks for all the info. i think i remember them being 16 way adj. i guess it's play time with the ol' struts.
  9. ck02wrx
    ck02wrx Member
    Yes, they are 16 way adj. I think it will be a personal preference on based on what feels good to you. Like you said, it's time to play. That said, I have my rear set at full stiff and front 2 clicks from full stiff. Also don't forget that you can adj. your front camber.
  10. monk
    mine go to 27 clicks past softest, but the manual says 16-way. i've got f&r set to 14 from softest, trying to find the right mix to gain "neutral" inheirent steering.
  11. miloman
    i always keep my rears stiffer than the front... works well for a little on/off ramp fun :D
  12. monk
    i'm guessing that induces oversteer ;)?
  13. miloman
    yup... but remember its lift throttle oversteer, not power oversteer... i only play around when theres nobody on the ramp besides me...
    i upgraded my springs to 8k all around the older tein flex springs were softer (i think 4-5k)... not sure what spring rates they come with now but ive heard they stiffened them up
  14. monk
    wrx 04 flex: 10/559 front, 8/448 rear
    i love just gliding through the long turns with a decent slip angle... it's my happy place ;)
    i'm guessing the oversteer is helpful in tight auto-x situations too?
  15. miloman
    yes it definitely is... i heard joel fehrman's car (probably one of the best autocrossers in atlanta) has significant toe-out in the rear on his STi :eek:hnoes: ... oversteer much?!?!?
  16. monk
    the guy must go through tires almost as fast as he goes through fuel ;)
  17. miloman
    well... he runs some rediculous race tires that are about 275 or more wide :eek:hnoes: ... they stick out like 2 inches beyond the fender :)
  18. 7wolf
    7wolf Member
    isn't he the guy who had an article in scubiesport a few issues ago?
  19. miloman
    havent been up to date on subiesport... sorry
  20. 1984
    1984 Member
    Yeah, Stompy was in Subiesport.
