Advice on 100K Mile Service for 05 RS
Discussion in 'Modifications & DIY how-to' started by bl-srt-4, Mar 16, 2011.
  1. bl-srt-4
    bl-srt-4 New Member
    My wife's RS just hit 108K, and I really need to get the timing belt changed. To my knowledge, all I really needed to have done is the timing belt and water pump. I've read different opinions on getting some of the pulleys changed, and possibly the cam/crank seals.
    We're on a pretty strict budget right now, so I'm not looking to get more work done than I have to. The schedule only calls for the timing belt, but what's a typical service look like?
    I'm definitely taking it to one of the recommended dealer alternatives to save a little, as well.
  2. nsvwrx
    nsvwrx Active Member
    You need to PM AllProSubaru. They will deff beat dealership prices with great service!
  3. John
    John Active Member
    I agree with nsvwrx about AllPro. Great guys over there.
    With a timing belt - change :
    *tensioner
    *pulleys
    *water pump
    You don't have to worry about the seals unless they are leaking.
    The reason for replacing the pulleys and tensioner is because failed timing belts are usually a result of these. They are moving parts and wear out over time. If one were to fail, you would have to rebuild your heads
  4. bl-srt-4
    bl-srt-4 New Member
    Thanks, guys...getting the pulleys definitely makes the price almost double, but I guess it's better to be safe than sorry.
  5. Alex
    Definitely, especially when sorry costs you more than the pulleys :)
  6. bl-srt-4
    bl-srt-4 New Member
    I ended up taking my wife's car to AllPro on the 4th. Brandon really took of everything we needed, and gave us an unbelievable price. I really can't say enough about the service they provided us!
    Thanks for the recommendations!
