Aftermarket recirc valve reviews
Discussion in 'Modifications & DIY how-to' started by crashtke, Sep 2, 2006.
  1. crashtke
    Anyone have any experience with the Forge recirculating valves? Any other recirculating valves to consider?
  2. moose
    I have a Perrin which I like.
  3. crashtke
    Are you using it with an aftermarket turbo I guess? And what psi you running?
  4. moose
    18.5 right now. It'll hold a lot more due to its design.
  5. nsvwrx
    nsvwrx Active Member
    the stock can hold up to 22 ish
  6. crashtke
    Ya, thinking mine is defective or leaking boost on part throttle....see the last post on the thread below this one.
  7. nsvwrx
    did you gtet nwe gaskets? try double gasketing
  8. crashtke
    I reused my old gasket, but it is the same noise as it was before the TMIC change. I guess I will try picking up a couple gaskets and doing the double gasket.
  9. nsvwrx
    i had the same problem reusing my old gasket.. a new gasket fixed it
  10. miloman
    i have the APS twin vent and have had no problems with it
  11. crashtke
    Is that the one that has a 50/50 or adjustable?
  12. miloman
    its sequential... at low boost levels, it recirculates everything... at higher boost, part is recirculated and part is dumped...
  13. crashtke
    Wow, kinda cool. And no bogging at shifts for you?
  14. Brian
    Brian Active Member
    I have a GFB hybrid. Same sequential deal and it holds big boost. :)
  15. 1ll-WRX
    I have a Worx tuning dual stage fully adjustable BOV/Recirc valve...holds just fine for me...I like the looks too
  16. crashtke
    Do you guys with the dual stage like milo's have any issues with bogging or rich conditions on shifts?
  17. miloman
    nope... never bogged... do have some occassional backfires but i had them with the 100% recirc valve too... the APS can also hold high boost and the atmospheric vent opens up only at high boost... at low boost, all the air is recirculated... not sure what the threshold is though
