airbag light
Discussion in 'Modifications & DIY how-to' started by bigb996, Jan 7, 2006.
  1. bigb996
    airbag light came on do i have to go to a dealer to cut it off or is it like something i can reset with and obdII reader or what? also is that bad?
  2. jt money
    well if the light is on its been turned off by the ecu and wont activate in an acedent. not sure if theres a clear for the code with out fixing the problem which most of the time is a short. my solution would be to locate the driver and pass side air bag harnesses and disconect and bush off and reconect tightly. look for loose wires and such at the same time. those are the 2 air bags that get the most vibration in my book.
  3. clemsonscooby
    clemsonscooby Active Member
    I got the light by disconnecting the airbag wire under the seat when I replaced the stock seat. Its difficult for it to come lose, but its possible.
  4. Alex
    I need to check mine, it's coming on and off. Which would make perfect sense, considering it sits right there underneath the seat.
  5. Meredith
    Meredith Banned
    Mine has been flashing, maybe it's because brian hasen't put the proper resistor in airbag line, cough cough....
  6. bigb996
    so if i unplug it under the seat it should go off?
  7. Alex
    the light or the airbag?
  8. bigb996
    airbag light
  9. Alex
    I would venture a guess to say if you unplugged it, the light would stay ON...maybe?ß
  10. wrxguy
    wrxguy Member
    Yeah just recheck the airbag connection and reset the ecu. If the cel code comes back then i would go to the dealer.
