Alignment Q
Discussion in 'Modifications & DIY how-to' started by Demo24, Dec 17, 2007.
  1. Demo24
    Demo24 Member
    I'm going to Gran tourismo on wednesday to get my car aligned. Should I just let them do what they feel is best for my car or should I ask for specific settings? I know toe should = 0, but camber I'm not sure what I should be going for, something in the -1.3-7 range?. I don't autocross so I need something thats good for the street and will not destroy my tires.
  2. Meredith
    Meredith Banned
    Jeff will ask you what your alignment needs are (ie autox track street etc) and he'll make suggestions. I usually follow his suggestions cause Jeff is the man! But then again I just request "as much negative camber as humanly possible".
  3. WJM
    if you can get 'more' than -0.9 front camber...you'll be doing good. Unless you've got other things going on...like adjustable stuff.
    otherwise for street use i recommend:
    0.00 (+/- 0.01) toe front and rear
    Stock rear camber (-1.5ish)
    -1.0 to -1.5 front camber (whatever you can get thats even side to side)
  4. SonicBoom
    SonicBoom Active Member
    There awesome up there... I'd just tell them what u use your car for and let them handle it.......
  5. FACE
    I'm set with -0.9 camber in the front and it is much more responsive to steering wheel input....That is as far as I wanted to go being a daily driver...
  6. Scotty B
    Scotty B Member
    i was aligned by them back in november right before the suby challenge...
    i went with 0 toe all around, stock rear camber and -1.3 up front (maxed out basically).
    i thought it would hunt really badly on the highway with no toe but it's really not bad at all. my tires are wearing decently. best of all, the car ran great at the autocross and i didn't kill my outside shoulders on my tires so i know it was making a difference compared to normally. the limits felt alot higher.
    GTE is a great facility with great people, i'd recommend them.
  7. Batlground
    Batlground Active Member
    What are you going to be doing with the car?
    Matt posting from Mikes name
  8. Demo24
    Demo24 Member
    just street driving, reasonably aggressive I guess.
    It's already been done! Pretty happy with them so I will go again, shame the drive is so far.
    Front's aren't cambered too much, I suspect that was to save the tires a bit. When I get some new tires I'll have them adjust it a bit more. Still I can tell a difference and I do like it!
  9. FACE
    How much camber did you get and what is your tire size? I think if I went anymore than -.9 it would be a bit much
  10. Meredith
    Meredith Banned
    If you run less then 1 degree of negative camber and plan to autox next year you will be eating the edges of your tires.... for the occassional autox you will be fine.
  11. Demo24
    Demo24 Member
    about -1.3 in rear, and around -.6 in front. considering I have some craptastic 205 coopers on 16" rims I'm not too worried. Just means it won't bite quite as hard in front, but theres not much helping on these tires.
    I'll get new tires early next year, haven't decided if I want more front or not.
    and I have no intentions to autox
  12. jesus888
    jesus888 Member
    How much do they charge for an alignment??
  13. Demo24
    Demo24 Member
  14. Eco Auto Clean
    Eco Auto Clean Active Member
    going to GTE tomorrow actually to get my boys RSX aligned...see how it goes!
  15. calmnothing
    I love my -2.7 front -1.2 rear setup. It's GRIPPY
  16. AXLEJOHNSON
    AXLEJOHNSON Member
    GTE FTW! I had mine done a couple weeks ago there, best alignment I have ever had. They have all my business in the future.
