All prices include shipping and paypal fees unless otherwise stated. Parts are in Augusta, GA for pick up, can negotiate a cash price – shipping. Will meet approximately 2hrs away for $500+ in parts (deposit req for time and gas). Offers accepted via PM, posted offers and lowballs will be ignored. Photobucket link to all parts and additional pics: http://s1134.photobucket.com/user/juztinvez/library/Cars/Car Parts ENGINE GSC S2 Cams for Single AVCS 2.5L – Used 200mi. Passengers side intake was replaced and is brand new - $700 Album: http://s1134.photobucket.com/user/juztinvez/library/Cars/Car Parts/GSC S2 Single AVCS cams ARP Custom Age 625+ head studs. 1x torque sequence to 100ft-lbs, 1200mi of use @ 8psi of boost - $400 New PTP T25 Turbo blanket Bought for smaller 30R tial housing, but PTP says it will fit stock size turbos - $150 Outfront rebuilt intake AVCS cam gears for Single AVCS 2.5L – $125 PS lines PTFE stainless braided high pressure line, rubber push fit return line with fire sleeve - $80 AEM EBCS with grimmspeed mounting bracket. Has all barbed fittings, I had use AN ones, Bulge in the wiring is the extra length coiled up - $90 Hallman Pro RX with ceramic ball and stiff spring - $75 New set of 16 valve spring seats – $15 Set of used stock STI valves from 16K mi heads. Spare intake and exhaust included. Make an offer
http://s1134.photobucket.com/user/juztinvez/library/Cars/Car Parts/Fuel and Intake 07 Engine harness with TGV and airpump plugs deleted, ID fuel injector plugs installed, Ground wire left intact for wideband engine ground - $120
EXTERIOR http://s1134.photobucket.com/user/juztinvez/library/Cars/Car Parts/Exterior Parts 06 WRX headlights with OEM HIDs and projectors. Work great lenses are pretty clear, no haze or yellowing but some scratches. All tabs intact. Wired for plug and play - $450 06-07 WRB Hood, couple chips, some fading on scoop -$200 will not ship Bayson R Ebay STI Limited copy lip - $50 prefer not to ship. Shipping extra. Thule roof rack for Wagons with roof rail delete Comes with 400 series feet Fit kit for Saab 9-2x/ Impreza wagons without rails Cross bars (42.5") 4 Lock cylinders for the feet Short roof adapter $275 Shipped
INTERIOR http://s1134.photobucket.com/user/juztinvez/library/Cars/Car Parts/Interior Parts 05+ WRX Airbag - $75 05+ center console, some wear on accessory door, no boot, no A/C module - $95 08+ telescoping Steering Column replacement or mod for 08-10 WRX’s - $80 GR column switches - $20
PAYPAL Fees need to be added or cash sale in person GTX3076R Rotated Turbo kit for 02-07 Kit was used for 1200mi and never saw more than 8psi Includes: Tigwerks 321 SS Vband up and downpipe DEI Ti wrapped Garrett GTX3076R turbo with Tial .82 A/R vband housing ceramic coated Tial 44mm MVR EWG with all springs and fittings 4" Intake with bungs for AOS vacuum and evap solenoid return, No maf/ Speed density AEM filter All oil and water lines included with fittings to heads, most fire sleeved. Mostly fragola fittings and prefabbed ptfe lines. Plumbed through Crawford AOS water heater. Crawford AOS included Killer B coolant reservoir included, req to clear intake. $3000 Album: http://s1134.photobucket.com/user/juztinvez/library/Cars/Car Parts/GTX3076R Rotated Turbo Kit Perrin FMIC Core with custom piping for above rotated setup: Black Perrin core, custom aluminum piping with AN fittings for positive pressure, AN lines included for EWG plumbing, AEM EBCS with AN fittings included, Tial 50mm BOV, and GM AIT sensor before throttle, Samco couplers with constant torque clamps. 2 90 deg coupler to fit gt30 outlet or gt35 - $900 Album: http://s1134.photobucket.com/user/juztinvez/library/Cars/Car Parts/02-07 Perrin FMIC Custom piping Outfront built 07 WRX heads, fit all 2.5L but will increase compression over STI heads. Built with Supertech parts: +1mm valves (exhausts are Inconel), ported bowls, dual valve springs with titanium retainers. Used: 18K mi cores, spun bearing (one journal has minor score, but cleared for use by Outfront), Built,ported, and run for 40mi, removed, tore down, and cleaned with GSC valve seals replaced. For asking price I will include grocery bag of all my spare buckets, Rebuilt AVCS came gears, and the stock cams - $1650 Album: http://s1134.photobucket.com/user/juztinvez/library/Cars/Car Parts/Built D25 heads
STOCK & Miscellaneous Comp Stage 3 2600 Full Face Ceramic clutch disc for 04-17 STI - $120 Exhaust AVCS cam gears off a 14 STI with failed motor. Used condition - $50 The lambda sensor in the headers, worked fine, wire shielding has a knick that could be heat shrinked -$50 Fender plug, from a legacy, but didn't fit my 07, think it works with 2.0L cars - $7 Make offers on anything below (last stop before the trash can) Rear sway bushings – Whitelines for 24mm and stock mounts. Perrin 19mm for stout mounts
WHEELS 2.5RS Goldies. Bought these as refinished OEMs, then bought new center caps, and tires. Had discount tire balance them only on the inside so clip ons would not ruin the lip finish. Tires are Kumho Ecsta 4X in 225/50/16 wheels are 16x7.5 5x100 +53. The car made it about 7000mi on the tires while the rest of the time was on jack stands - $600 will not ship Album: http://s1134.photobucket.com/user/juztinvez/library/Cars/Car Parts/Wheels
He said he already has rails so he may just get tyhe T1 conversion injectors. If you want them let me know. Getting a lot of interest on the facebawls. Can ship same or next day depending on payment or will be flying out of Atlanta Monday, but at 4PM so traffic may be bad.
Yup make an offer shipped or I'll be flying out of Atlanta Monday afternoon and could try to meet early
Dinner meet at GC BBQ in Roswell? If you do I can stop by. It is not far from home. Any possibility you'll have the lambda sensors? I'll have the money for it. I wish I knew where to do PM on this new website!
