Another flywheel question.
Discussion in 'Introduce Yourself' started by mattprzy, Jun 1, 2006.
  1. mattprzy
    mattprzy Active Member
    I'm still thinking of getting one. However, my friend has caused me to think some more and I need to ask you guys what you think. He was telling me it's more popular for N/A cars than turbos and he dosn't know if it's a good mod with a turbo. I'm just double checking because I really don't want things to break on me again. Lighter flywheel won't hurt right?
  2. Demo24
    Demo24 Member
    just dont go to light
  3. feelthebreak
    feelthebreak Member
    a lighter flywheel is fine for a turbo car, it while help the turbo someone a little faster and accelerate better. but you don't want something like a 9lb aluminum flywheel because it will probably end up costing you problems.
    i would recommend a 13-14lb chromoly steel flywheel. i know cobbtuning.com sells the ACT flywheel for your car.
  4. MrCoffeeATL
    MrCoffeeATL Member
    I had a 12.9 pound flywheel on my legacy (stock was 28) and i hated it. It was not very friendly on steep hills and rattled/screamed a lot on deceleration. I got misfire codes from the ECU, i am told, because it spins very freely and decelerates too fast. I went with an old 2.5 RS flywheel which is about 16-18 pounds and love it. Very driveable, cheap, and it revs faster which was my initial goal.
    I believe there was a recall for your year WRX that put in a heavier flywheel to solve misfire codes (don't quote me on that one) so going too light could indeed cause problems with CELs and drivability. I would find someone with a flywheel of the weight you think you like and drive it around for 20 min. You'll see right away if it's something you want to mess with.
    Sorry if i sound very downer about flywheels but i've played the game and gone too lite and hated driving the car in stop and go on hills (285/85 interchange anyone?). Just want you to be sure you want this with potential downsides noted.
  5. WrxCrazy
    WrxCrazy Active Member
    get stage 1 flywheel, & clutch.. u will be fine for the horse power u want which i'm guessing below 300 whp or 250 whp.. around
