Any ideas on cleaning buildup from inside intercooler y-pipe?
Discussion in 'Modifications & DIY how-to' started by keeganxt, Jan 22, 2008.
  1. keeganxt
    keeganxt Active Member
    Nov 13, 2006
    1,071
    0
    Got any ideas for a good cleaner or brush or anything that will eat through the oil buildup and gunk that dries up and just sits there inside the y-pipe (mine at least)?
    This is mainly due to the y-pipe being used...fyi
  2. clemsonscooby
    clemsonscooby Active Member
    Dec 13, 2005
    1,536
    0
    409 or purple power and let soak. PP works wonders on my pipes.
    #2 clemsonscooby, Jan 22, 2008
  3. awdlaunch132
    awdlaunch132 Member
    Jul 2, 2007
    280
    0
    brake cleaner will probably work well.
  4. keeganxt
    Nov 13, 2006
    1,071
    0
    will the brake cleaner evaporate pretty well
  5. clemsonscooby
    Dec 13, 2005
    1,536
    0
    Yeah, brake cleaner evaporates fast, but it will leave the crud there. You definitely need to rinse it with something or use a lot of brake cleaner and hold the pipe up so it flushes out.
  6. FACE
    Oct 5, 2006
    3,286
    6
    brake cleaner...its the new tide!
    You clean just about anything with brake cleaner. Evaps very quickly
