How far away is the nearest water source. Is your house on a crawl, basement, or slab. If it is on a slab you might need a prof. If not I could help you with it.
Hmm well it was built in 2003/4, there is a bathroom with a sink directly behind the wall I hope to mount it too, so Id say maybe 6 inches away is the nearest source. No basement or crawl space
build on a slab like mine can be fun Since you have a drain and h/c pipe close by to tap into, this should be fairly easy. good luck
yeah that is easy stuff man. I mean thats all I know how to do is work on crap like that stuff and build stuff. Genya, let me know if you want help as well...
i am a professional. i`m a union 2nd year apprentice. 3 more years i turn out and i`ll be making $30.00+ an hour. woot.
Im a n00b on home improvement, so any assistance would be greatly appreciated! :bowdown: , Scoob looking to get the work sink sometime in the next week or two, and guess any misc parts Id need. Weapon any inexpensive suggested sinks youve seen? Feel, what was involved in getting a apprenticenship, just curious. Thanks again
supply tubes.. copper fittings.. type L copper is the best to use.. p-trap.. plumbers putty to seal the strainer.. solder and flux.. etc etc. mapp gas torch should work fine. where in woodstock are you genya?
