Anybody know this P# or have a diagram?
Discussion in 'Modifications & DIY how-to' started by hank87, Jul 22, 2012.
  1. hank87
    hank87 New Member
    I've got a 04 wrx(completely stock) with a 180k on it. My check engine light came on friday going down 75 and it started idling between 1500 to 2500 rpms when stopped. I figured I just needed to clean my idle air control valve. But theres oil all around this gasket type ring. Any ideas or suggestions.
  2. hank87
    hank87 New Member
    Also I got a code p0519 from the auto parts store diagnostic test.
  3. b reel
    needs new PCV assembly, a thorough upper intake cleansing and check for vacuum leaks at the connections. usually the hoses will have cracks and/or splits on the ends.
  4. hank87
    hank87 New Member
    would you happen to know the P#'s for that? I cant find the whole assembly.
  5. h23bb2
    h23bb2 Member
    Its just an intercooler to throttle body coupler.
    The dealer should be able to look it up no problem.
  6. WRXbryanATL
    WRXbryanATL Member
    I got one sent from allpro next day delivery for like $25 i think
  7. lucky13
    lucky13 Member
    You can also get one at any auto parts store. Look in the intake section.
  8. hank87
    hank87 New Member
    Alright I cleaned the pcv valve and replaced the air control valve gasket(it was in two pieces). Now it won't crank, it sounds like its not getting any fuel, and ideas or suggestions?
    thanks
