Anyone done the 3/16th mod?
Discussion in 'Modifications & DIY how-to' started by Demo24, Oct 31, 2007.
  1. Demo24
    Demo24 Member
    Well I came back across this mod today and have been considering doing this. Faster spool times with slightly more boost sounds good to me and all for under 2 bucks works for my wallet as well. :naughty:
    Thinking about going 3/32nd's instead to try and ward off some of the negatives that the 3/16th's can occasionally present with.
    anybody here with experience in this mod? I don't have a boost gauge yet so if I do, do this it will only be noticed by the ass dyno.
  2. 5spdfrk
    5spdfrk Active Member
    From all that's been said, I wouldn't bother with it.
  3. FACE
    So how does this mod work?
  4. WJM
    Just dont do it...period.
    get a REAL TUNE instead.
  5. FACE
    Wasn't planning on it...waiting for warr. to run out!
  6. WJM
    your 5 year/60,000 powertrain warranty I hope...;)
  7. Kokopelli
    Haven't seen this mod in a while.
    It doesn't cost much and you get what you pay for.
    I wouldn't bother.
  8. Demo24
    Demo24 Member
    hmm, ok I won't bother then.
  9. WJM
    ^^Good.
  10. Demo24
    Demo24 Member
    just curious as to why it is so bad. I can't see a lot of issues with it besides boost spiking, thus why I was planning on 3/32
  11. WJM
    Ummmm...yeah.
    BOOOOOOOMMMMMMMMM!
  12. goixiz
    goixiz Active Member
    if you cant tune for that you will get boost fluctuations or overboost conditions.
    What you are creating is less flow to the actuator hence less leakage and more initial boost.
    YOu would overboost but not to apoint where it will exceed 20psi or some crazy number. your CEL will come on first and if stock ECU/ROm it will actually limp your car before it goes kaboom.
    I can do something even better for free and less chance of boost fluctuations
  13. nsvwrx
    nsvwrx Active Member
    what your doing is letting less air though to the 'thing' that opens the waste gate, AND the air that gets there is slower to get there.. hence its you over boost AND build boost faster than your ECU can compensate for.
    in other words BOOM!
  14. goixiz
    cmon dont scare him
    it wont go boom if you didnt go crazy with the mod (like pinch the tube)
    worst is it will fluctuate boost a lot (cycling) or spike a few psi more than target.
    (i assume he is stock EM) its just not a pleasant drive.
    There are checks in the EM that prevents a lot of unwanted conditions but may not catch all when you start to gowild with mods
  15. GTscoob
    Cmon man you can build an MBC for less than $20, just do that and set it at 16psi or so and make sure you have a boost gauge so you can watch out for partial throttle full boost. 3/16 mod is ghetto as hell, at least with a MBC you can somewhat control your boost.
  16. siegelracing
    You get what you pay for.
    Siegel
  17. FACE
    ^^^ thats why we pay you!
  18. WJM
    Bad idea again.
    There is a reason the stock 2.0 WRX runs 13.93 PSI and not 16 PSI from the factory.
  19. Demo24
    Demo24 Member
    I was under the impression it let more air through.
    I was looking for an easy way to help smooth things out a bit, and more boost earlyer sounded good as well. Getting rather tired of the annoying power fluctuations I get under heavy throttle.
  20. nsvwrx
  21. WJM
    More air thru the restictor means LESS BOOST.
  22. nsvwrx
    its supposed to make it smoother.. just get EM..
    read the article i poted.
  23. Demo24
    Demo24 Member
    I have, and the 26 page one on nasioc.
    and I would get em if I had 600 bucks to blow at the moment
  24. goixiz
    or $95 and a laptop and some patience
    yes it lets more air through to the BCS = less air to the actuator = more boost
  25. Demo24
    Demo24 Member
    yeah, there is that way. I looked into it for awhile, but I don't really want to tune myself on this car. And it just seemed a bit iffy overall. Granted if done right it can be quite good. I just dont want to take the chance
