anyone have experience with IC leaks?
Discussion in 'Introduce Yourself' started by nsvwrx, Aug 16, 2006.
  1. nsvwrx
    nsvwrx Active Member
    i must havea few.. only seeing 13.1 psi
    and im not sure where they are ! ahh
  2. JJang12
    JJang12 Active Member
    Most common place is between TB and IC. Also don't overlook IC's bottom side. Just take out the IC and reclamp the whole thing. Make sure all the clamps are not stripped.
  3. jt money
  4. Alex
    Just run outside and simply double check the connections (dont forget the air return lines on the right side).
