I'll be looking into a set of track wheels in the not too distant future, and unless i get a killer deal on oem BBS wheels, I'd like to get the zigens so, what size and offset are you running and have you had any rubbing issues?
I run 275 V710s on my BBS with a 5 mil spacer. I still have some rubber in the rear underhard turning at an autox course.
LOL...sorry, i should have spec'd the actual wheel huh, that would have been really helpfull... 17x8 FNO1R-C's of course
They do not come in an offset that's really for a streetsetup, people still use them (myself, greg now, etc). The only offset offered in that size that fits the car is the 35. If you move up to their 18", they offer a 48 offset.
SIZE OFFSET BOLT PATTERN APPLICATIONS WEIGHT 18 x 7.5 35 5x100 Celica 18 x 19 lbs 42 4x100 Civic, Integra 42 4x114.3 Accord, Sentra, G20 42 5x114.3 RSX, Altima, Camry, IS 300 Front 48 5x100 Impreza WRX, Legacy 48 5x114.3 Prelude, Accord V6 SIZE OFFSET BOLT PATTERN APPLICATIONS WEIGHT 17 x 8.0 35 4x114.3 S13 Rear, S14 base model 16 - 18.0 lbs 25 5x114,3 EVO VIII, S14, Z32, 350Z, V35 Front, Mustang Front 35 5x100 Impreza WRX, 04 STI, Neon, Cavalier, Celica 35 5x114.3 FD3S, MR2 Front, NSX Front, FC3S Front 43 4x114.3 IS300 Front, RSX, etc 48 5x100 Impreza WRX Sedan (Except STI) SIZE OFFSET BOLT PATTERN APPLICATIONS WEIGHT 18 x 8.5 30 5x114.3 EVO VIII, 350Z Front, S14 Front 21.5 - 22 lbs 38 5x114.3 RX-7, MR-2 43 4x114.3 IS300 Rear 48 5x100 Impreza WRX / STI (04) 48 5x114.3 Impreza WRX / STI (05)
crap, i was hoping to run 17s... but i guess the issue is not being able to lock the steering wheel with a 35 offset? so alex have you tracked them without tearing up the tires?
The issue is the rear, with an offset that wide on the 2004 I was having fender rubbing issues. But, the 05+ stis have a .25 to .5" wider rear fender on each side. James was having minimal issues with my wheels, he ended up raising his coilovers a tiny bit and voila! Why not just get a set of Rota's ?
Hey, somehow I missed this thread... I did have some rubbing issues in the rear after installing the wheels, but after raising the rear to match the front (1.00"), there has only been one instance of rubbing and that was an unavoidable deep pothole. I wouldn't suggest them if you are just running springs.
alex: i want to run the zigens because they're so ligh... and sexy james: i have tein flex that i'm putting on, and i only lower it enough for the control arm to be 90deg loaded. these wheels will be track-only
I understand why you want the zigens, its why I bought them Go for the 17x8 then, or try the 18x8.5 for the pure track bling :bigthumb:
