AP received today
Discussion in 'Modifications & DIY how-to' started by yerrow, Feb 17, 2005.
  1. yerrow
    yerrow Active Member
    so is my AP already loaded with the current maps or do i have to load them from the computer? i booted it up and it looks like they're already there
  2. BlueBox
    BlueBox Member
    I would think they would be the latest. Might be worth a call as they did release some new ones a few weeks ago though I haven't bothered to go look myself.
    If you do go download the new ones save the old ones off of the AP in a folder on your pc first. You never know which your car may respond best to. Last time I checked (and it's been a while) it was difficult to tell what the revison numbers are so save to a folder with that name.
  3. JJang12
    JJang12 Active Member
  4. Alex
    have fun :bigthumb:
  5. yerrow
    already have
  6. PapitoSTi
    PapitoSTi Member
    Running Stage 2 93oct for STi. Wanna race? :D
    Had to special order my AP because I was going from ECUTek to AP but everything worked out just fine.
  7. JJang12
    hmm.... ecuTek to AP??? that's like opposite compare to the flow of others.
    wat's up???
  8. PapitoSTi
    PapitoSTi Member
    ECUTek is great. But I wanted control of my ecu. I did not like going back to a tuner everytime I changed a mod or added a new one. Plus I get the option to go back to stock on the fly and other maps. I tested them both and I like the AP better. Yeah that's the opposite of the flow but I like to experiment :bigthumb:
  9. Alex
    Understandably interesting...
  10. ScoobyMike
    ScoobyMike OG Mod
    Yeh you can still go back to stock, only on the wrx not the sti. The wrx you can run 2 different boost maps. I think milo runs a 19.6 psi map and the other is a 8 psi map.
  11. FTZ
    Can't switch maps on 05 WRX.
  12. miloman
    cant really go back to the stock map safely after changing the restrictors... but the 8psi map makes about 175whp
  13. PapitoSTi
    PapitoSTi Member
    You can switch to stock real map on the Sti :slap:
  14. socrates42
    socrates42 Member
    y the switch?
  15. PapitoSTi
    PapitoSTi Member
    I haven't switch but you never know if you have to go back to stock for instance; emmision test, warranty issues, etc.
