AP v1 Stage2 questions...
Discussion in 'Modifications & DIY how-to' started by cannarella, Jun 28, 2007.
  1. cannarella
    cannarella Member
    So I have a '05 Saabaru manual with a gutted UP and Turbo XS Stealthback. I the latest stage 2 map for 91 octane loaded. I took my Tactrix cable and looked at the IAM after a couple days of driving and it was at 9. Also my boost would not go over 14psi and I see it should be peeking around 16. Will adjusting the WG arm fix my boost problem? I am guessing so. Does anyone know what is the IAM set to when that map is loaded. From what little I know, the IAM should be at 16. Can anyone offer any pointers?
    Thanks
    Andy
  2. nsvwrx
    nsvwrx Active Member
    why are you on 91? we have 93 here.. load that map up .. reset your ecu and your car should take a few days to reach max boost on the map +-.5psi
  3. cannarella
    cannarella Member
    I will load her up for the drive home. I guess I was wondering about what would happen with a bad tank of gas... But hey, I'm game.
  4. goixiz
    goixiz Active Member
    BAse map 91 and realtime 93 - youll be fine
  5. cannarella
    cannarella Member
    I flashed the 93 map and the IAM started at 12 then went to 16 then backed off to 15. I am going to do a pull tomorrow moring and get some data to see how the boost is doing.
