AVC-R Install/Setup Questions?
Discussion in 'Modifications & DIY how-to' started by integroid, Nov 17, 2008.
  1. integroid
    Well I have an AVC-r and had questions to anyone that has used one or setup one before. Honestly, I would probably be better with just a simple Electronic Boost Controller but I have the AVC-r and already purchased it so why not use it.
    My questions are
    1. Do you have to use the throttle signal?
    2. Can you use the AVC-R as just a boost controller without all the fancy different gear set limits?
    Anyone with experience want to help me out with the install/setup?
  2. slowwrx
    With a subaru its better to set it up gear based
  3. crashtke
    Not much point over the factory set up if you are not using the gear specific boost imho.
  4. siegelracing
    Yes it needs to be hooked up to the throttle. If you're not going gear based, put a manual on it. We have the new TopSpeed MBC for $69.95 and they work like CHAMPS.
    Siegel
  5. integroid
    Got a pic of it so I can see it?
  6. slowwrx
    Siegel...I know you aren't recommending manual boost controlers...I'm going to kick you in the nuts.
  7. siegelracing
    For a setup that can run the same boost in all gears, they just plain work. They're simple, reliable and consistent. Only the good ones like the Hallman Pro and the TopSpeed one though ;)
    Siegel
  8. integroid
    So let's see the topspeed one!!!!
