axel nut?!?!
Discussion in 'Modifications & DIY how-to' started by miloman, Jul 28, 2005.
  1. miloman
    anyone know what that is?
    don't say ...' duh... its the nut on the axel'
  2. jt money
    do you mean the nut thats holds the hub on? ill see if i can find a pic
  3. SkullWRX
    SkullWRX Member
    i know it's specced torque is 145 ft-lbs after some mild searching, but i can't find a desciption of the part. The rear wheel might turn when torquing it, so JT's suggestion sounds about right
  4. jt money
    look at the center
  5. jonnyboy0150
    jonnyboy0150 Member
    Not sure about Subaru, but some cars not only have a torque spec, but also a special procedure for installing an axle nut, what are you trying to do with it exactly???
  6. miloman
    jt: thanks for the link
    jonnyboy: ive been experiencing a clicking noise that seems to originate from the driver's side front wheel area... it clicks when im switching from accel to decel or backwards... after doing some research on nasioc, it seems like a lot of people having this problem have solved it by tightening the axel nut
  7. jonnyboy0150
    jonnyboy0150 Member
    That sucks man, well good luck with it man!!
  8. miloman
    thanks... i was afraid it would be something expensive/disastrous... hopefully this will solve the problem
  9. Genya
    I got a spare one here i believe, its not too hard to do. Not expensive at all.
  10. MrCoffeeATL
    MrCoffeeATL Member
    *mrcoffee searches for his marble. The last place he saw it was milo's car...oh well, it'll show up."
  11. jonnyboy0150
    jonnyboy0150 Member
    Is it just loose or something milo??? it might possibly be the half-shaft joints. But definitely try the nut first, its cheaper!
  12. miloman
    i dunno if its loose or not... hoping it is... all i know is that the car is making a noise and some people have fixed it by tightening that nut
  13. gueryjones
    gueryjones Member
    Let me know when you figure out what size it is. I might have a socket for it. Axel nuts tend to be pretty frickin huge and the sockets are like $15 apiece or something, i.e. not really worth it to buy and use once.
  14. miloman
    i was gonna go up to SOG next week and have scott take a look at it... i probably don't have time to do anything before that cuz of finals... appreciate the offer buddy
  15. SkullWRX
    SkullWRX Member
    if you need sockets and stuff, mine go up to 27mm and i've got a wrench that'll do 145ftlb. just let me know if you need them
  16. miloman
    awesome... thanks for the offer... i'll let u know if i can make some time
