Bacon-Wrapped Stuffed Shrimp
Discussion in 'Kitchen & Cellar' started by jt money, Nov 20, 2006.
  1. jt money
    It's shrimp, it's bacon, it's cheese; what's not to like? Find some large shrimp, a wooden skewer, and cook the bacon about halfway to done before you begin. Mix up some seasoning and the cilantro-ranch dipping sauce, and you're minutes away from scarfing down a delectable dish that's meant to be a teaser for what's to come. Looks like you'd better make the main coarse a real doozy.
    Seasoning
    1/4 teaspoon salt
    1/4 teaspoon paprika
    dash ground black pepper
    dash cayenne pepper
    dash allspice
    Dipping Sauce
    1/3 cup ranch dressing
    1/4 teaspoon dried cilantro
    (or 1/2 teaspoon fresh minced cilantro)
    5 pieces bacon
    5 large shrimp
    3 slices fresh jalapeno
    1 ounce pepper jack cheese
    When skewering, be sure to face all the shrimp the right direction
    -- like a tight little Rockettes kick line.
    1. Preheat oven to broil.
    2. Make the seasoning blend by combining the ingredients in a small bowl. Set this aside.
    3. Make the dipping sauce by combining the ranch dressing with cilantro in a medium bowl.
    4. Cook the bacon in a frying pan over medium/high heat, but don't cook it all the way to crispy. You want undercooked bacon that, when cool, will easily wrap around the shrimp. Cook the bacon about 3 minutes per side, and don't let it brown. When the bacon is done lay it on paper towels to drain and cool.
    5. Shell the shrimp, leaving the last segment of the shell and the tail. Remove the dark vein from the back of the shrimp, and then cut down into the back of the shrimp, without cutting all the way through, so that the shrimp is nearly butterflied open. This will make a pocket for the pepper and cheese.
    6. Pour 1 cup of water into a small bowl. Add the shrimp and jalapeno peppers and microwave for 60 to 90 seconds. Shrimp should be starting to firm up and change color. Immediately pour the water out of the bowl, remove the jalapeno slices and pour cold water over the shrimp. Place the the shrimp and jalapeno pepper slices onto paper towels to drain off excess water.
    7. Build the appetizer by cutting the jalapeno slices in half and removing the seeds. You should now have 6 jalapeno slices -- you'll need 5 of these. Place one slice into the slit on the back of a shrimp. Cut an inch-long chunk of cheese (about 1/4-inch thick), and place it on the jalapeno slice. Wrap a piece of bacon around the shrimp, starting where the cheese is. Start wrapping with the thinnest end of the bacon. Go 1 1/2 times around the shrimp and then cut of the excess bacon and slide a skewer through the shrimp, starting with the end where the cheese is and piercing the cut end of the bacon on the other side. Repeat with the remaining shrimp and slide them onto the skewer. When skewering, be sure to face all the shrimp the same direction -- like a tight little Rockettes kick line.
    8. Put the skewer onto a baking sheet or broiler pan and sprinkle a very light coating of the seasoning blend over the shrimp, then broil for 3 to 4 minutes or until the bacon begins to brown and the cheese begins to ooze. Serve over a bed of rice if desired. Feed the left over bacon pieces to the dog while you scarf out on the shrimp.
    Serves 2 as an appetizer.
  2. bluetwo
    bluetwo Active Member
    Damn that does look good...
    Now I'm really hungry! :hs:
  3. moose
    Very nice!
    Reminds me of Atomic Buffalo Turds. :)
  4. MarkM2016GTI
    Man JT...That sounds delicious...I need to make that one day...
    My mouth is watering...Yummm...
    Mark
  5. Alex
    Sounds yummy, Ive got shrimp and bacon in the fridge....wait so why am I sitting here still.
  6. rexrocker
    Event at 7:45am with my cup of coffee, this sounds awesome! Will certainly have to give this a shot! Ever attempted this on the grill? Might be an interesting twist.
  7. monk
    while we're on stuffing things...
    Stuffed Mushrooms (reagular whites are fine, but i like doing baby bellas)
    1lbs mushrooms
    8 tbsp butter
    1.5 cu. sauage or ham
    3/4 cu. finely chopped celery
    1.5 cu finely chopped onion
    .5 tsp salt
    .5 tsp pepper
    .5 tsp thyme
    .5 tsp margarine
    2 tbsp lemon juice
    1 cu. dried breadcrumbs
    1 egg beaten
    1 tbsp burgundy or red wine
    rinse and dry mushrooms.
    remove the stems and mince stems
    Heat 2 tbsp butter in large skillet.
    Add stems, pork, onion, and celery. sautee 5 min or until tender.
    Stir in spices breadcrumbs, egg and 1tbsp lemon juice, combine evenly.
    Melt remaining 6 tbsp butter, add wine and remaining lemon juice.
    Dipp mushroom cap tops into mixture and set onto baking sheet.
    make firm balls with sausage mixture and place them into each cap.
    Drizzle remaining wine-butter over finished caps.
    Broil 4" from heat until golden brown.
