Bad wheel bearing
Discussion in 'Modifications & DIY how-to' started by Goose013, Aug 15, 2005.
  1. Goose013
    Goose013 Member
    I apparently have a bad bearing in my d/s front wheel, does anyone know if I can just re-pack the bearings or what will need to be done. Thanks
  2. Brian
    Brian Active Member
    Depends on how bad. Jack that wheel up and feel for movement. If the bearings are allowing some movement don't drive it *at all*. If they are just making noise you might be able to get away with just greasing for a little while.
    I have a 2 ton bearing press if you need to use one.
  3. jt money
    i had to have mine replaced a few thousand miles ago. costed me 600 for both fronts installed. sux
  4. jonnyboy0150
    jonnyboy0150 Member
    They are most likely sealed bearings, if they are indeed bad, they will need to be replaced! :(
  5. bigb996
    my front one squeeks guess i will need to do something to it sometime.
  6. Goose013
    Goose013 Member
    so I'm looking at about $300 for one installed, but does anyone know how much just the parts run? I've got access to any tools I need; so if I can do it myself that would be great. Thanks for the info guys.
  7. jt money
    i really dont remember sorry. i believe its still over 100. maybe ss will grace our sight and chime in.
  8. Alex
    Well, the subaru parts site says the OEM wheel bearing cost roughly $60.
    Part No. 28316 "Bearing-front axle"
  9. gotsol
    gotsol Active Member
    pull the entire hub out and take it to a dealer or shop
  10. Goose013
    Goose013 Member
    so not as bad as I thought...good. Very helpful. I didn't think about looking on the subaru site Alex, I looked on the SOG site instead and didn't see it.
  11. Genya
    Front bearings arent too bad to replace, the rears ugh. Good luck! The manual is posted somewhere around here, and it has a step by step.
  12. Goose013
    Goose013 Member
    I found it on nasioc, doesn't look bad at all, I think I have access to all the tools I'll need. thanks
