can anyone illustrate where the headlight separates when your baking it?....i'm having a little trouble.... Thanks :ugh:
http://infamousracing.com/luis/IMG_1428.JPG there are little tabs such as the one on the bottom on this pic you will need to seperate. If I wasnt at work id try to find a better picture.
the tabs that run around the outside?....i have a 03 but still should be the same...i guess it's not hot enough yet then...thanks for the help bro....i just don't want to leave it in too long...
Yup those tabs, when you push the housing back together they should slip back on top of each other. Here is a good thread for 02+ headlights? http://forums.nasioc.com/forums/showthread.php?t=358666&highlight=baking+headlight
