Justin has put a lot of work into this car and it shows, Ill try and get some good pictures of the engine bay this week when we finish installing the Moroso AOS, Coolant Tanks, And Reservoirs. More about the build Ball Racing Track 1 Short Block Ball Racing Track 1 Head Package Blouch Dom 1.5 Turbo (10cm) Full Exhaust UnEqual Length Header TGV Deletes AMR Top Mount Intercooler Theres lots of other parts on this car but this covers most of it. They had some trouble with the fuel pump so Justin is replacing it and having the car retuned. Doug did an awesome job with the tune. Its the only stock location turbo that I feel like makes the power it should while maintaining awesome spool. Its the perfect daily driver setup.
Check the voltage at the pump to make sure it isn't the controller. I think Doug checked all that when it was on the dyno.
