bank1 o2 sensor
Discussion in 'Modifications & DIY how-to' started by Dheim96, Jun 13, 2013.
  1. Dheim96
    Dheim96 Member
    This morning when I started my car I heard a weird noise kind of like an exhaust leak. At low speeds I can hear it but when I speed up it kind of goes away. I dont feel a difference in power with the car. The check engine light and cruise light came on so I had the code pulled. It said bank 1 o2 sensor. After some research is looks like it could be that sensor or a couple other things like a leak in the intake manifold gasket. Either way this sucks.
  2. Find weird noise first>It may be causing sensor to get incorrect data thereby tripping the fault code.
  3. Dheim96
    Dheim96 Member
    A boost leak test should find where that noise is coming from I hope. Are they expensive to get done?
  4. Dheim96
    Dheim96 Member
    One of the screws on the maf got stripped. Whats the best way of getting it out?
  5. integroid
    A Drill
  6. Dheim96
    Dheim96 Member
    Would a bad cat cause the car to sound like an old beat up honda and throw the bad o2 code?
  7. techlord
    I doubt it as the cat is post o2. Make a boost leak tester out of PVC and hook to air compressor. Regulate pressure below 15psi
  8. integroid
    Sounds like you have a huge exhaust leak pre O2 sensor.
  9. outbacksprt
    outbacksprt Member
    o2 sensor unscrewing itself??
  10. Dheim96
    Dheim96 Member
    Thats what I was thinking.
