Battery Relocated to Trunk
Discussion in 'Modifications & DIY how-to' started by jonnyboy0150, Jun 21, 2006.
  1. jonnyboy0150
    jonnyboy0150 Member
    Next week I plan on relocating my battery to the trunk to free up some underhood space. I have and Optima red-top and i found this mount kit especially for it, and it looks clean as hell...
    I also found a 1 gauge battery cable kit as well which should be big enough, most recommend at least a 2 gauge wire.
    Have any of you guys relocated your battery? If so, are there any pointers or tips that would help with the installation?? Thanks!
  2. goixiz
    goixiz Active Member
    find a used subwoofer box and recarpet it and line it with plastic (inside) to make it look stealth in your trunk.
    If you are cheap like me then go to a liquor store and get a wooden wine box and recarpet it
  3. jonnyboy0150
    jonnyboy0150 Member
    Word!
    Im thinking that the best way to run the cables would be though the car under the door threshold trim. Id like to see how someone else has routed the wiring.
  4. Brian
    Brian Active Member
    Most racing/track organizations require relocated batteries to be in a special container, i.e. a sealed plastic container that vents/drains outside the passenger compartment/trunk. Summit Racing sells relocation kits for <$100.
  5. Cool_____
    Mine is in the trunk. I used 4 gauge wire and it works just fine. Took the fatory braces and made them work in the truck. Battery is located on the passeger side above the charcoal canisters towards the rear of the trunk. I ran the wires down the drivers side below the fuel lines and seperated the two with rubber material. A power distribution box connects the power wire to the rest of the factory wires in the engine bay. Frees up a lot of room and makes changing spark plugs a lot easier.
  6. Alex
    Cool dude, post some pics when you're done.
  7. Ayrton
    Ayrton Member
    If you ever plan to drag the car, you will need a cut off switch as well. I would also highly recommend an inline fuse on the positive wire close to the battery.
  8. Cool_____
    I need to install an inline fuse on mine. I'll try to get some pics up.
  9. jonnyboy0150
    jonnyboy0150 Member
    Yeah id love to see some pics!
  10. clemsonscooby
    clemsonscooby Active Member
    What are you going to do with the free space?
  11. miloman
    emergency 12 pack holder :D
  12. Cool_____
    I dunno about jonnyboy but with the FMIC piping running right thru there and the bigger Optima battery, it was a recipe for a boost leak. The piping was rubbing the battery a good bit.
  13. jonnyboy0150
    jonnyboy0150 Member
    Well the optima battery post locations are a little different causing the battery to sit a little crooked. And with meth, the meth pump is getting crammed between the crooked battery and the tank. I would just like to free everything up some. And with that billet mount in the trunk, it should be a pretty clean set-up. Id still like to see some pics of where some of you have mounted it just to get some ideas.
  14. Cool_____
    Here's the distribution block (I bought the wrong kind but it works) in the engine bay...man it look funny without the meth kit :(
    Here you can see the battery wire going into the grommet on the firewall
    Battery view with tiedown and ground
    Yeah I know my trunk is dirty so what...
  15. jonnyboy0150
    jonnyboy0150 Member
    Thats pretty sick, so whats the deal with the missing meth kit??
  16. Cool_____
  17. jonnyboy0150
    jonnyboy0150 Member
    Dude, that sucks balls! Was it a manufacturer's defect??
  18. Cool_____
    Yep. Steve at SMC inspected and it was a bad faulty seal. The new was sent back to me yesterday so I hope to get it tomorrow or Monday at the latest.
  19. jonnyboy0150
    jonnyboy0150 Member
    Yeah i had a broken test button on the front of the module, and he had it fixed and returned to me, no questions asked, in like 3 or 4 days. He does an awesome job!
    But yeah, glad to hear you didnt have any engine damage because of it!
  20. Cool_____
    Yep. I realized I was DRINKING meth and then there was a hesitation right when the meth was supposed to come on. It would wait a second the then WHAM tq kicked in. It supposed to just go WHAM!
    That was when I knew something was up. If there is the slightest thing different or funny I get paranoid and I am glad I do.
