BC Coilovers
Discussion in 'Modifications & DIY how-to' started by WRXCoupe, May 16, 2009.
  1. WRXCoupe
    WRXCoupe Active Member
    I have had these for about two months now. Like any coilover it takes a while to set it up like you want it. After working through various ride height, spring pre-load and damper settings, I have finally got my BC's set up for DD at close to stock ride height, with a stock spec alignment, dialed in about midway on the damper settings.
    These things are really phenomenal for the money! They are completely daily drivable. You can barely tell that I have coil overs as they are set up right now. They even withstood the ultimate test on Juniper street in midtown which is an absolute pathetic, tragic, road surface failure.
    They can be set up a whole lot more aggressively as I experienced while finding the right set up. As far as daily driving this coilover, two thumbs way up. The girlfriend has even given them the Tata friendly approval(& not the car manufacturer: "Tata" :naughty:).
