BC coilovers
Discussion in 'Vendor "For Sale" Classifieds' started by Maximum Output, Oct 27, 2009.
  1. Maximum Output
    Maximum Output New Member
    Hello WRXAtlanta!!!
    We just wanted to let everyone know we have, added BC coilovers to our product lines. These Coilovers are available for purchase here. Be sure to pm us for availability.
    BC Racing BR SERIES
    $999.99 shipped.
    The BR-series coilover kit is perfect for street driving and occasional road course duty. With easily accessible ride height, having a performance coilover system couldn't be easier. You chose how low or high you want your vehicle (no preset ride heights here), and the patented concave lower locking ring keeps it locked in. All systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. Available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive-looking coilover system
    Mono-tube shock design
    30 levels of damping force adjustment, adjusts compression/rebound
    Pillowball mounts / adjustable camber plates included with certain applications
    Rear racing camber plates optional
    Separate full length height adjustable
    One year full warranty
    Rebuildable after 1 year warranty expires for only $95 for life!
    BC Racing RAM series
    $1150.00 shipped
    [- Inverted Mono-tube shock design
    - 8kg Front / 6kg Rear Springs
    - Other spring rates available (email for details)
    - 30 levels of damping force
    - Pillowball/camber plate mounts included
    - Adjustable rear camber plates available
    - Separate Full length height adjustable
    - One year warranty
    - Rebuildable
    BC Racing ER Series
    $1750.00 shipped
    the much anticipated External Reservoir, double adjustable coilovers are finally available for 02+ wrx/04sti, 05-07 STI, And both the 08+WRX and 08+STI. whats new about these? It features Large external reservoirs front + rear, Separate reboung and compression adjustments and a twin piston design. The external reservoirs hold much more fluid then coilovers without to allow the car to operate much longer before over heating on the track. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune their setup using the separate, 30 way, rebound and compression dials.
    features:
    External reservoir Mono-Tube shock design
    30 levels of damping force adjustment, adjusts both compression and rebound separately
    Twin Piston Design
    Pillowball mounts and adjustable camber plates included (where applicable)
    One year warranty
    rebuildable
    BE SURE TO PM US REGARDING AVAILIBILITY
    Thanks,
    Chris
    Maximum Output
