belt or ?
Discussion in 'Modifications & DIY how-to' started by knhtrdr, Jul 20, 2008.
  1. knhtrdr
    knhtrdr Active Member
    when I start up the car when its cold it chirps/whistle a bit. is that a belt or is there something else I should be looking for. just recently got my 90-100k serv done 2months ago.
  2. kingwrex
    kingwrex Supporting Member
    did they replace the belts? could be te a/c or alternator belts if not. alos could be a pulley.
  3. knhtrdr
    Nope, got oil plugs n timing done I was told that was all that was needed.
  4. kingwrex
    you should start with replacing those belts then
  5. knhtrdr
    Dang it. I need a headlight bulb too and dose anybody know the color code for wrb need to touch up my hood scoop its peelin somethin terrible.
  6. knhtrdr
    Thankx that wouldnt mean I have to get the timing done again would it?
  7. FACE
    Paint code for WRB is OC2
  8. FACE
    No you can just replace those belts...let me know if you want to do it youself of have someone hook it up for you ;)
  9. knhtrdr
  10. crashtke
    Also look at the idler pullies...had one go out on me around that time.
  11. I had the same chirp about a month ago, replaced both belts and the chirp is gone. They are really simple to replace.
