BIg Ballers 500whp WRX dyno vid/chart
Discussion in 'Member Journals & Project Build Stories' started by Batlground, Aug 28, 2007.
  1. Batlground
    Batlground Active Member
    Here it is, 500AWHP on PUMP GAS, NO METHANOL.
    The car was barely even working up a steam to get those numbers, we know there is more left in it, but the ARP gods frowned upon us. We lost the passenger side head gasket late fri night. We have already pulled the motor an gotten new head gaskets car should be back together by friday.
    2 Center ARP studs had come loose and caused the head gasket failure. There is alot of discussion on how to solve this problem in the subarus since retorquing the studs is so hard to do (IE you have to pull the motor).
    I think we have come up with a solution and it shouldnt give us any more trouble.
  2. savsuby
    savsuby Member
    Wow That thing is going to be crazy.
  3. josh booth
    josh booth Active Member
    WOW!! That is all I can say. That thing sounds crazy.
  4. Cool_____
    hEHEHEHEHEEHE
  5. Alex
    Nice, moved to Engine Internal.
  6. BKiller
    BKiller Active Member
    Sweet...
  7. Cool_____
    I don't think this should be in engine internal....the head stud thread should be though.
  8. miloman
    Agreed. Moved to Members Journals.
  9. Cool_____
    That beast sounds like a freaking motorcycle.
  10. blindfold
    blindfold Active Member
    can you post a graph with x-axis on RPM instead of speed?
  11. slowwrx
    Sure but for future refrence, the cross over point is 5250rpms.
    Matt
  12. Batlground
    in RPM, the run is cut short becasue we lost tach signal
  13. Doug@DBW Motorsports
    need to put the bottle on that thing.
  14. Jake
    isn't the crossover point ALWAYS 5250rpm?!?!
  15. Brian
    Brian Active Member
    yup
  16. blindfold
    congrats man, that's for more than impressive on pump gas
  17. Batlground
    we might lol
    this is without AVCS too
  18. slowwrx
    We have the kit, I've just been to lazy to put it on.
    Matt
  19. nsvwrx
    nsvwrx Active Member
    5250 for all cars?
  20. Batlground
    Great. Now you sound like Matt...."spray nitrous on that bitch!" Give me a break for once with the nitrous. G's.
    ~Tracy
  21. Jake
    yeah 5250 for ALL CARS.
    look around at any dyno chart for any vehicle.
  22. BrianGT
    It is actually 5252
    Code:
                            Torque * RPM
    Horsepower      =       ------------
                                5252
  23. Cool_____
    Why is the tq kinda low though? I'd think it would be more squared out? I know AVCS isn't used but still shouldn't it be higher or is it because of the big turbo?
  24. Doug@DBW Motorsports
    Nitrous makes everything better, see what i would do is throw a big turbo on there. Say f the spool and just spray it. It is a drag car right, who cares about spool.
  25. Cool_____
    Yep drag cars care less about spool as they are always at 5K+ rpms.
  26. slowwrx
    The torque is low because there is virtually no timing in it. The torque will start coming up as soon as Dan gets aggresive with it.
  27. techlord
    You get the engine back in the beast yet?
  28. slowwrx
    No, I'm going over there tommrow to work on it.
    Matt
  29. Cool_____
    Man you better have that beast running before I show up Thursday!
  30. Batlground
    You two should get married.
    ~Tracy
  31. slowwrx
    Eat a dick
  32. slowwrx
    I'm supposed to pick up the motor from the engine shop this week. It will go back in depending on how crazy things are at BG, with the new drift car going together for SEMA I don't know if there will be time.
  33. Cool_____
    What took so long? Didn't it only need a head gasket or did you guys decide to do even more to it?
  34. Ben@TTR
    Ben@TTR Member
    What was your solution to the arp problem? I'm building my ej25 with the same studs.
  35. slowwrx
    Two of the buckets in the head got swapped and it was making a noise so I pulled it back out and took it up there to let them check everything.
    So far the only known solution is to pull the motor after the first good heat cycle and retorque the heads.
    We tried something different but I don't want to say until I'm sure it works. I don't like to spread misinformation and I would hate for someone to try it and it fail.
    Matt
  36. Cool_____
    You can simply heat the coolant passages up like Doug mentioned and then tq them down after an hour or so. It wasn't an ARP problem....it was an ARP + Cometic gasket problem.
  37. slowwrx
    We don't really know that for sure without more testing. The cometic gaskets are MLS just like factory there is no reason for them to fail. Guys use them in 2000 HP Mustangs.
    Hopefully heating the coolant passages will work.
  38. slowwrx
    Its back.....
    I dropped the motor back in it last night. Hopefully we can tune it as soon as I get back from Colorado on the 4th
  39. truegiant
    truegiant Member
    awesome
    now that the head/gasket situation is solved I cannot wait to see some more numbers.. Is it more or does it seem like it takes it forever to get to redline on the dyno? but those numbers are impressive non the less. Is that the intake manifold that you guys have for sale on IA??
  40. slowwrx
    That manifold on IA was built by turbodave this is a Magnus. The reason it takes so long is Dan starts the pull below 2000 rpms, so he can adjust the fueling all the way through the power band.
  41. FACE
    Wow!
  42. ballistic
    ballistic Member
    Matt I better not see that motor back in the shop.
    And someone is gonna have to change the name of this thread when we get some new numbers lol.
