Bleeding brakes is a pretty simple procedure. I've never had any questions about it until i noticed my front brakes had 2 bleeder valves on each caliper! What is the correct procedure to bleed these? I'm guessing just do one valve, then the other, then move to the next caliper? The only other thing that I can think of is to pump up the brakes and then release both of them at the same time but that doesn't make much sence to me... ??
Sweet that answered my question. Thanks!!! For anyone that doesn't want to watch and has the same question, the procedure is to bleed the inside portion using the bleeder valve that is closest to the inside of the car, then do the same with the outside.
