Blinking CEL
Discussion in 'Modifications & DIY how-to' started by Slowsoul, Oct 16, 2006.
  1. Slowsoul
    Slowsoul Member
    What is it, why did it happen?
    2002 WRX, turboback catless exhaust, cobb stage 2 map, comptech flywheel.
    I was near the top of third around 5-6k. It flashed about 6 times and then stopped. Tried to pull the code with my access port, but I got nothing back. I was about a quart low on oil. Hasn't happened again.
    I have read that the lighter flywheel can cause misfire codes...could be?
    My main question here is what does the blinking CEL mean?
  2. miloman
    here's what i found on clubwrx
  3. 5spdfrk
    5spdfrk Active Member
    Yeh, flashing CELs are never a good thing imo.
  4. Slowsoul
    Slowsoul Member
    clubwrx was the only place I didn't check...go figure.
    Thanks.
    I'll keep reading.
  5. miloman
    i usually try a google search and see if i get hits on nasioc, iwsti or clubwrx
  6. Alex
    Hmm, I bet you hit some sort of boost cut. It'll flash the CEL when you do that. I forget the code, its P0205 or something like that (overboost).
  7. miloman
    i thought boost cut flashed the cruise light... its been a long time since i hit boost cut
  8. crashtke
    Nope mine flashed the check engine light then stayed on when I overboosted. Had to clear it with the ap.
  9. Slowsoul
    Slowsoul Member
    I thought that the AP eliminated the boost cut altogether.
    I have been looking for the post about lightweight flywheels and misfire CELs...can't find it.
  10. Alex
    Hmm, you might be right. Let me check my overboost thread :p
    ...I stand corrected, overboost will cause a CEL (which in turn disables cruise and blinks the cruise indicator)
  11. crashtke
    No with street tuner you have the ability to disable the codes, but it does not automatically disable the overboost code. In fact I would not want it to...if I am going over 22 psi I really want to know about it.
