Blown Top Radiator Hose
Discussion in 'Modifications & DIY how-to' started by feene1, Jun 23, 2008.
  1. feene1
    feene1 Member
    Dec 7, 2006
    32
    0
    So it looks like my top radiator hose seperated in the middle where it looks like 2 hoses are sealed together. It is the left most junction. I doubt this is reason for concern, just replace it right?
    Is this something that is covered by the 50k powertrain warrenty?
    Would I be better just buying a hose kit like Turbo XS or just doing it myself with a new stock hose?
    Any help would be great.
    Thanks
    Rob
  2. Sparta
    May 2, 2007
    3,693
    12
    You sure its not on a crack on the radiator? I've got a stocker if decide to buy one.
  3. feene1
    feene1 Member
    Dec 7, 2006
    32
    0
    Ya I see it leaking out around it when i squeeze it.
  4. Brian
    Brian Active Member
    Mar 29, 2005
    1,236
    0
    FYI, I recently had to replace that hose. The radiator fan was cutting into it and the hose finally gave out. Make sure you "choke up" on the hose mountings to keep the hose away from the fan.
  5. FACE
    Oct 5, 2006
    3,286
    6
    I have also seen where the altanater pulley has eaten a hose as well
  6. Trey
    Trey Active Member
    Mar 20, 2005
    1,322
    0
    Looks like the hose popped where it was rubbing on that hard line. Mine did the same thing. Just spend the $7 and replace it yourself.
