Boost Gauge install at SOG
Discussion in 'General Community' started by SomethingNew, Jul 22, 2008.
  1. SomethingNew
    SomethingNew New Member
    Hi,
    I don't know if this is the right spot, and if not, you can totally move it. But anyways, I'm ordering a prosport green mechanical boost gauge soon, but I was thinking about getting SOG to install it for me, because if something goes wrong I don't want to be responsible and I have faith in Subaru's service departments. But I was wondering if anyone knew if they would do it. I know I should just call them, but I figured I check here to see if anyone has gotten them to install a boost gauge before. If you have how much was it, and how long did it take?
  2. nsvwrx
    nsvwrx Active Member
    Get it done at TopSpeed or BatlGround instead!
  3. SomethingNew
    Would it be more/less/the same for cost wise?
  4. nsvwrx
    should be nearly the same, but those shops are MUCH more performance oriented and stand behind their work.
  5. Doug@DBW Motorsports
    not much that can go wrong with a boost gauge
  6. Sparta
    You'd be wasting you money IMO. If something went wrong SOG probably won't stand behinf it since its aftermarket. Eventhough I doubt a boost gauge will cause any problems.
    I say find some local members in your area and do it. Should only take about 30 min
  7. SomethingNew
    Hrm, alright...My biggest fear is the cutting of the boost line to fit the T adapter.
  8. Davidwrx
    Davidwrx Member
    I installed my own gauge. It was the Lamco subaru gauge. It wasn't too bad. I have the instructions if needed. I am guessing it would take someone who has done it before between 30 min and 1 hour. That should give you an idea as to how much it would cost.
    BTW - Cutting the boost line was no big deal.
  9. dontcallitarex
    dontcallitarex Active Member
    Not true. Mine gave me a boost leak.
    Home depot tee ftl.
  10. Tray@topspeed
    Tray@topspeed Member
    Bring it here. Our secretary Tiffany can put it on for you. ;)
  11. J_P
    ^^^Famous last words^^^
    In all honesty it's a pretty simple job. Takes some time and patience getting through the firewall. If you don't feel comfortable doing it yourself have a g2g install day and you can get advice and hands on help if you need it.
  12. BKiller
    BKiller Active Member
    Get a quote from SOG and I will do it for 1/2 that amount...
  13. FACE
    very simple install IMO pm me if you want some help!
