Boost gauge install question
Discussion in 'Modifications & DIY how-to' started by bigb996, Oct 11, 2005.
  1. bigb996
    yes another thread for this. Really all i need is a picture of someones under hood so i can see how you tapped the hose into the vacuum line. I bought an autometer mechanical boost gauge and am wanting to see the best way to plug it up.
  2. RADON
    RADON Member
  3. bigb996
    wow thanks man that explained it all easily. I appreciate that. What is best to T it off with? is there some kinda piece i can buy?
  4. wrxin8or
    Yeah you can get a vacuum t connector from napa or someplace like that. make sure you get the right size, which if i remember is 1/4 inch ID.
  5. RADON
    RADON Member
    I used a SS reducing tee - 1/4" to 1/4" to 1/8". The tubing ID that ran from the 'T' to the sensor was just a bit larger than 1/8". Nothing a zip tie didn't fix.
    I ordered from McMaster as it was the only place I could find a small tee. It's product number 5670K35 on page 117. Same size tee, but different material 5117K33 on page 114. www.mcmaster.com
  6. bigb996
    thanks man
