Boost gauge question
Discussion in 'Modifications & DIY how-to' started by V_WRX, Sep 27, 2005.
  1. V_WRX
    V_WRX Member
    The factory boost gauge on my rex doesn't light up anymore. I opened it up and changed the bulb (which was burned) but it still doesn't light up when i turn my headlights on. Anyone have any suggestions on what I can do to get it on? The gauge itself works fine, it's just that it doesn't light up.
  2. ShaneSTI
    ShaneSTI Active Member
    maybe the fuse blew as well?
  3. Alex
    Check the fuses and double check the connection between the bulb and the wiring. If memory served me, the soldering looked pretty weak there.
  4. rexrocker
    If it's not the fuse or wiring at the bulb, check the wires to their source. The stock boost guage gets it's power from the radio. You can follow the wires down the steering column and back towards the radio...this will require you to remove the plastic column cover and pull the radio.
  5. V_WRX
    V_WRX Member
    Thanks for the replies, guys. I'll take a look at the problem when i have some time.
  6. WrxCrazy
    WrxCrazy Active Member
    yo dude.. u have a short wire that goes up ur butt cheek!!!
    rofl sorry j/k
    btw u heard my tranny got fked up? call me and ask :(
  7. goixiz
    goixiz Active Member
    volt meter
    ohm the bulb
    then check the voltage at the buld then the source
    Process of elimination
  8. V_WRX
    V_WRX Member
    hey, what happened to ur tranny wrxcrazy? I'll give you a call tomorrow. I've allready checked the bulb and the fuses, had to replace the bulb but it still doesn't light up. I got a voltmeter and will check the ohm tommorow, but i have to take my audio headunit out to do this. Does anybody have any idea how to take the central dash cover off? Do i just pry it off with a screwdriver?
  9. WrxCrazy
    or we could just call, american idol guest judges.. :eek:hnoes:
  10. V_WRX
    V_WRX Member
    Edit: Fixed. Now waiting for the helix dnas to get here.
