I am in the process of wrapping up the last few things on our new server setup but I have run into an issue that I cannot seem to solve. I have triple checked the configuration files but for some reason phpmyadmin continues to generate this error, "Error establishing a database connection" via http connection. This of course, should be an indication that credentials are incorrect. However, I am able to access the database with the phpmyadmin user via CLI mysql. I have uninstalled and reinstalled both mysql and phpmyadmin. The odd thing is that if you try and wget the localhost/phpymadmin in the console, it pops a 404 error. Code: user@machine:/# wget localhost/phpmyadmin --2010-07-17 20:34:41-- http://localhost/phpmyadmin Resolving localhost... 127.0.0.1 Connecting to localhost|127.0.0.1|:80... connected. HTTP request sent, awaiting response... 404 Not Found 2010-07-17 20:34:41 ERROR 404: Not Found. I am at a loss and am half-way tempted to wipe the drive and do a fresh OS install and work through it all again. Thoughts?
Good idea, Ill go over and look again. I do not recall moving mysql from the standard port (3306). Edit -- Just checked my.cnf in the /etc/mysql dir and it shows the correct, default, port configuration.
just to check, apache(2) is running correct? when I installed phpmyadmin on my box I had to create a symlink from the /var/www folder to /etc/phpmyadmin where it is installed. If this is in place, you can also check that the apache2 settings are correct. Sometimes they hide phpmyadmin in a virtual host file.
Also a good idea with the symlink, but it did not seem to do anything. MrCoffee is suggesting I had to have missed a package somewhere. I am about to just wipe and run another giant apt-get install, lol.
